Oil injection problems
Old Oct 24, 2007 | 08:38 PM
Jiu Jitsu77's Avatar
Default Oil injection problems
I got a 91 Trail boss 250 that had a burned up piston. i put a new one in but i dont know if the oil injector is working. that may have been why the piston went bad. what i want to know is can i just mix the oil in the gas at first to make sure the motor works properly before i jump the gun and buy a new oil injector? any help would be great. thanks
Old Oct 24, 2007 | 08:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
alot of times when they rebuild 2 strokes they premix the gas/oil for the first tank as well as the oil injestion. when you say burned the piston, what do you mean? did it burn a hole in the top of it or did it melt the slides to the rings? alot of times if the oil injection stops it will seize the engine and the crank bearings. burning the piston is usually due to too much air or a lack of gas, or running too hot of a spark plug.
Old Oct 24, 2007 | 10:19 PM
when i took apart the motor the piston was black from the rings on up. the cylinder walls werent scratched much.
Old Oct 24, 2007 | 10:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like it had carbon build up. did you do a compression test before you rebuilt it to see if it needed it.
Old Oct 24, 2007 | 10:48 PM
when i got it it did not run. who ever had it before me tried to take the motor out because when i pulled it there were motor mounts missing.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
