Trail blazer oil ratio?
Old Oct 25, 2007 | 01:21 AM
79hugger's Avatar
Default Trail blazer oil ratio?
Just did a top end rebuild on a buddys Trail Blazer,he still has a good working oil injection system but I wanted to run a premix in the tank for break in.I am thinking a 40:1 ratio , if so how much oil in oz is that per gallon.I may talk him into doing away with the injection but still need to know
Old Oct 25, 2007 | 08:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think you would be better off w/ a 32 to 1 premix. personally i wouldnt do away w/ the oil injection as they hardly ever break down and are alot easier to deal with. i think its like 2 ozs. / gallon but dont quote me. just an idear, go buy those (i think its 5oz bottle) little chainsaw/ weed trimmer 2 cycle oil bottles and use them i think there good for 2 1/2 gallons. i use them and split in half in a 1 gallon can on my saw/ trimmer. runs a little rich but doesnt hurt to be safe.
Old Oct 25, 2007 | 12:10 PM
Blacksheep5's Avatar
at the dealer they also sell a little measuring cup just for 2 stroke oil
Old Oct 25, 2007 | 06:41 PM
ftwflh's Avatar
40:1 is proper amount for premix but if you are running the injector too I would just add a few ounces to the tank for break in.
Old Oct 25, 2007 | 07:57 PM
embler's Avatar
just had my uncle's trailblazer rebuilt and the mechanic at the dealer said not to put more oil in the gas. it'll add to much oil and it won't break in properly. they said to just vary the throttle at times and donthold it wide open for extended periods for the first 2 tanks of gas. after that, its all out.
Old Oct 25, 2007 | 11:44 PM
79hugger's Avatar
I have another question, is it ok to run a nonsynthetic oil say Bel ray 2 stroke in the polaris? The owner has no idea what oil is in it,he bought it not running,I believe it is Maxima 2 stroke due to the sweet smell but who knows it might be outboard oil somebody put in it or maybe it's the reason it had a .050 ring gap at tear down and 50 psi compression,what ever it was it's drained out.I'm doing some other work at the moment on the atv,I called it a peice of crap to start with but its coming around.I have a case of belray S2 2 stroke oil "injector or premix" I'm tempted to run in it but unsure,I suppose its a touchy subject on oil as far as preference,some say do not use synthetic oils during break in?
Old Oct 26, 2007 | 07:50 AM
ftwflh's Avatar
I personally like to run a nonsynthetic because I like to see the smoke and know it is getting oil.The Polaris blue is what is recomended for non and Polaris gold for synthetic.I would see no reason not to run BelRay if you have it on hand.
Old Oct 26, 2007 | 12:07 PM
I run Amsoil Interceptor oil in my TB
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
