2000 sp 500 shift problem
Old Oct 27, 2007 | 06:20 PM
munnspencer's Avatar
Default 2000 sp 500 shift problem
i was going up a hill and put it in low and once i got to the top i tryed to get it in high but wount go help me
Old Oct 27, 2007 | 08:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
so even when you shut it off or rocked it it was still stuck in? did you check linkage for any problmes? if its not linkage chances are in the shifting fork may be bent. just a thought.
Old Oct 27, 2007 | 09:00 PM
yeah ive tryed all of those and it still its stuck i have no clue
Old Oct 28, 2007 | 12:31 AM
jdaddy's Avatar
munns, my 700 got stuck in high after a friend rode it, it wasn't the linkage, it was the gear box, ground up gear, first if your ride is idling fast will not want to shift through H L N R P well. if it is a simular problem to mine, it is a fairly easy fix, $12 part, couple of hours (a little trial and error) taking apart and putting back togather the gear box. the box i'm speaking of has a black cover at the end of the linkage, if you still can't get it to shift, i would take this box apart and look at the gears. go to the polaris web site and look at a diagram of the box, it will give you an idea of what you'll find. go luck bro.
Old Oct 28, 2007 | 09:05 AM
9bcomput's Avatar
I agree with Jdaddy, its the little black box.....
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
