Mounting a 2000# Warn on Explorer?
Old Jan 7, 2001 | 02:37 AM
pete/ny's Avatar
I am getting a 2000 # Warn for my Explorer and need alittle help. I have the factory double tube bumper with the square plate in between to mount the rollerhead. Question is- what mounting kit do I need or will the winch bolt right up and into the space behind the tubes? Also, will the stock battery be sufficent to power the winch? Thanks Pete
Old Jan 7, 2001 | 04:56 PM
PolarisMan's Avatar
I dont know about the bumper, but the battery i think will survive ok, as long as the radiator, lights, or any other things are going when u start to pull with the winch, i also think that it helps alot if u charge the battery very well, before installing the winch
Old Jan 7, 2001 | 06:22 PM
hvydutyf250's Avatar
the winch mount that you should need is polaris part no.#2872337.i think you can get just the mount or you can get the whole kit which has the warn 2000lb winch included. i hope this helps you out.
Old Jan 7, 2001 | 07:48 PM
MEANGREENMACHINE's Avatar
I ordered my winch mount bracket from cabellas. I have the same bumper that you have. The roller fairlead doesn't fit very snug on the bumper but it still works. Your battery will hold up when you are winching yourself out if you give it about half throttle. Otherwise it'll run the batttery down quick and you'll have to pullstart it. You will definetely not regret buying the winch when you get stuck. They work great.
95wolv
Sep 27, 2024 12:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
EIF
Apr 20, 2017 07:15 PM
panicmanic
Sep 28, 2015 12:59 PM
toonces
Sep 5, 2015 01:14 PM
