attn: vmax1500
Old Jan 7, 2001 | 10:46 AM
Jeepers's Avatar
sorry to have to do this - I tried email but it comes back undeliverable - need some info on your motion pro - I tried some time ago to get one but was told "special order". Was yours, or are they now available to the unwashed masses
Old Jan 8, 2001 | 08:17 PM
Vmax1500's Avatar
I used a "universal" setup for dirtbikes/atv's. Motion Pro "Turbo" twist throttle p/n: 01-057.
The cable I used was definatly for a dirtbike since it is little too long for the atv. But, I re-routed it to take up the slack without putting the cable in a bind, or in harms way.
The cable was Motion Pro p/n: M.P. 01-236.
This cable may be avialable in shorter lengths with the same ends, but, the shop I was at didn't have it in stock, and this worked for me.
I ended up shifting everthing to the left on the handlebar, kept the housing so the 4wd switch would have a mounting place, but removed the thumb lever & linkage inside the housing. (Be sure to plug up the holes).
I'll never go back to a thumb throttle again!!!
aaronrkelly
Feb 25, 2010 07:58 AM
mechanx
May 4, 2007 01:11 PM
dooski7c
Jun 16, 2005 12:04 PM
