spring spacers
Old Oct 31, 2007 | 12:41 AM
02huntinquad's Avatar
Default spring spacers
is it possible to get a little more lift out of the back springs by adding a spacer between the spring itself and the adjustable end on the bottom of the spring. right now i have the adjuster cranked, and it just doesnt seem to give the back end enough stiffness.
Old Oct 31, 2007 | 03:40 AM
dosceola's Avatar
i dunno cause other things will limit how much space u can make there. might be able to put stiffer springs on there
Old Oct 31, 2007 | 07:22 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like you need stiffer springs for sure. the lift/spacers will bring it up but you still wont have a good feeling spring i wouldnt think.
Old Oct 31, 2007 | 01:37 PM
SCRAMMYTODD's Avatar
If you have access to a lathe I have engineered drawings for a 1" spacer for the rear. I have never made one for the rear, but I made a set for the front and they work really well. Send me a PM if you want me to e-mail the designs to you. Or you could buy some heavy duty springs. I have EPI HD front springs in mine and when I lift my plow the bike only sags 1/2"
Old Oct 31, 2007 | 07:16 PM
onesavage's Avatar
my"HIGHLIFTER" front springs are by far the BEST mod i have done,,and i"ve done a few...i can raise my 60"plow without any sag ,at all..it rides sooooooooo much bettter and i cannot believe how easy it steers....i AM COMPLETELY sold on "HIGHLIFTER" springs....check out my pics
Old Nov 1, 2007 | 07:15 PM
azlobo's Avatar
I put some EPI heavy duty springs and a spacer on the front end of my 03 Polaris Sportsman 500 HO. It took all the sag away and gave me at least an inch clearance under my front end. The ride is more rigid without the soft springs and the quad looks agressive without the sag. I used a 2" plastic electrical coupler for the spacer and it worked out well. The coupler is 2 1/2" long. You have to remove the strut to fit the spacer on top of the strut mount. FYI, the heavy duty springs are one inch shorter then the stock springs even though they are more rigid. I still had a little sag with just the heavy duty springs but with the spacer on, the sag is GONE!
Old Nov 1, 2007 | 10:51 PM
onesavage's Avatar
yep!!!!!
Old Nov 1, 2007 | 11:53 PM
thanks for the input, i think i'm going to try putting spacers in the rear springs for starters, and if i need more i'll get a set of heavier springs.
Old Nov 2, 2007 | 09:18 AM
colt2245p's Avatar
i have made several 3/4 inch sets and installed. just did one last week on a 05 800efi for a friend it raised it a total of 1.5 inches from where it used to sit. we use a piece of 2" conduit tubing i have seen where people used pvc pipe,.... i dont think that would hould up well
Old Nov 2, 2007 | 09:43 PM
the good thing about being a welder i can fab up alot of cool stuff, and it lasts alot longer than pvc pipe
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
