Speed limiter???
Old Nov 2, 2007 | 04:52 PM
Polaris350's Avatar
Default Speed limiter???
I have trail boss 350 and when I turn the key on the wires coming out of the speed limiter are smoking. I was wondering if could just get rid of the speed limiter all together instead of spending 65.00 for a new one. Any thoughts???
Old Nov 2, 2007 | 11:22 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I would check to see if you have a DEAD SHORT to ground when your turning the key switch on!!!!
...........Caper...........
Old Nov 2, 2007 | 11:32 PM
Polaris350's Avatar
How do you find that and what is it????
Old Nov 2, 2007 | 11:41 PM
Charlie's Avatar
Is this the speed limeter module or switch at the throttle that is smoking? Disconnecting the black wire at the module disables the system for that model year. It wont hurt anything other than disable that safety feature. There must be a wire that is is also shorted that goes to it and it is under the fuel tank shroud on the left side. You will find a circuit board for all the wiring.
Old Nov 2, 2007 | 11:43 PM
Well you will need a multi-meter set to OHMS.....And this will tell you if the wire going to your switch is damaged or BARE somewhere that may be in contact with the steel of frame ......(rubbing).................................To do this all you need to do is with the meter test leads............Put one test lead on the wire from the switch and the other to a good clean bare steel on the quad................................Don't turn the key on you can do this without power(12 volts)....................................Do this to both wires on each side of the switch............................................ ..This will tell you if there is any short to the steel frame!!!......................Do you understand what I am saying?...........Caper...........
Old Nov 2, 2007 | 11:58 PM
Polaris350's Avatar
the white wire coming out of the limiter box glows orange and smokes real bad when u turn the key on......
Old Nov 3, 2007 | 12:04 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like a dead short
Old Nov 3, 2007 | 02:35 PM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Polaris350
the white wire coming out of the limiter box glows orange and smokes real bad when u turn the key on......</end quote></div>
Unplug all the wires on the limiter and throw it away. You don't have to have it for the unit to run. It will however run very fast in reverse so be carefull.
Pehter
Oct 3, 2024 11:00 PM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
ReconBayou
Sep 23, 2015 02:41 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
