trailblazer troubles
Old Nov 4, 2007 | 05:37 PM
ksdan's Avatar
Default trailblazer troubles
hey all, helping my old ladys brother out with his 00 trailblazer 250, this thing is torn apart in my garage and driving me nuts.
first off, he ran it with the choke out for 15 minutes or so, when he brought it to me the plug was burnt up pretty good but turned over fine. He said it started bogging on him, wouldnt rev, finally died and wouldnt start.
I put in a new plug and it coughed a little, no start. I've gone through all the connections, but I cant get any spark with the plug out of the cylinder, seems to have a very weak and/or intermittent spark.
my question is this, will a fried CDI cause this problem or would I have no fire at all with a bad CDI? also does anyone know how to test the coil?
Old Nov 4, 2007 | 07:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would say when they go they go. maybe coil.
Old Nov 10, 2007 | 04:18 PM
ksdan's Avatar
replaced the coil, still getting weak *** spark. anybody know how to test the stator output?
Old Nov 10, 2007 | 04:32 PM
ksdan's Avatar
also checked compression just for the hell of it- 60 lbs, but thats with a cold engine, couldnt get it warm, still sounds kinda low to me. also, the bike will sit and sputter for as long as you want with the throttle wide open, let off the throttle and it dies. any ideas?
Old Nov 10, 2007 | 04:45 PM
hoytultratec's Avatar
60 is low even cold
Old Nov 10, 2007 | 04:47 PM
sounds like its time for a top end rebuild.
Old Nov 11, 2007 | 11:52 AM
ksdan's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: hoytultratec
sounds like its time for a top end rebuild.</end quote></div>
probly so, being run with the choke out most likely the culprit. I'd still like to get good spark before I pull the head though. Anyone out there got a stator for sale?
Old Nov 11, 2007 | 12:12 PM
ftwflh's Avatar
I would do the topend first then check the spark.I may have a stator pm me later today.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
chewy78
Sep 8, 2015 10:37 AM
