clutch slips on my daughter's Champ?
Raptorman01, Sounds like you need a new clutch they are not hard to replace if its the original clutch probably is deffinatly bad, I havent had any expierance with this type of quad but I had a kaw lakota which used the same type of clutch you can adjust by turning screw on clutch backwards and then turn clockwise untill it gets snug. At least thats how you did it on the Lakota. I would replace the clutch if this doesnt work, as I stated before its not hard save yourself some $$$ and do it your self, buy a service manual this will tell you everything you need to know and in the long run it will save you alot of $$$ in labor fees.
Lou Domenech
Sep 11, 2015 06:35 PM
cdstang
Aug 31, 2015 07:52 AM
