banshee electrical
Take them off, and unplug a litte wire (with 3 connectors) under the fuel tank. You can't just "take them off". You'll need to replace the carb tops, throttle cable, and make sure you unplug the wires at the throttle (if it's still the thumb). Don't forget the little 3 connector wire under the tank.
Zorro is correct...be sure to get new tops for the carbs....and do yourself a favor and fill the plugs with rtv silicon to prevent water corrosion once unplugged. Rust has a way of working itself up exposed wires doing alot of damage.
Sw00p
Sep 24, 2015 02:50 PM
