banshee electrical
Old Jan 7, 2001 | 09:26 PM
Bigbore's Avatar
Was wondering if any body knows any why to by pass the switches that are on the carbs.
Old Jan 8, 2001 | 01:51 PM
Zorro's Avatar
Take them off, and unplug a litte wire (with 3 connectors) under the fuel tank. You can't just "take them off". You'll need to replace the carb tops, throttle cable, and make sure you unplug the wires at the throttle (if it's still the thumb). Don't forget the little 3 connector wire under the tank.
Old Jan 8, 2001 | 05:50 PM
sAyIt_fmf's Avatar
Zorro is correct...be sure to get new tops for the carbs....and do yourself a favor and fill the plugs with rtv silicon to prevent water corrosion once unplugged. Rust has a way of working itself up exposed wires doing alot of damage.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
