trail Boss 350 4X4 no rear break....
Old Nov 11, 2007 | 06:48 PM
Polaris350's Avatar
Default trail Boss 350 4X4 no rear break....
My rear break i think just went out on me. The pedel just goes all the way down, no stopping power at all.......any ideas before I start taking things apart.
Old Nov 11, 2007 | 07:03 PM
hoytultratec's Avatar
hole in the brake line, check the brake fluid if its low start checking for leakes.
Old Nov 11, 2007 | 10:18 PM
ftwflh's Avatar
loosen the jam nut and turn the bolt in until the pads touch the rotor then back it off a little.
ForestTrails's Avatar
Linkage from foot pedle came off. if you can stilll stop with the hand break. (That does both front and back and it is hydrolic.)The foot pedal is mechanical only and rear break only.
Old Nov 11, 2007 | 10:37 PM
Polaris350's Avatar
Are you saying that the hand break works both the front and rear break at the same time......and that the foot pedal is mechical.....
Old Nov 11, 2007 | 11:28 PM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Polaris350
Are you saying that the hand break works both the front and rear break at the same time......and that the foot pedal is mechical.....</end quote></div>
Yep
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Gnuters
Jul 19, 2015 10:03 AM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
