1999 Warrior Problems
Old Nov 13, 2007 | 11:54 AM
buckaholic2000's Avatar
Default 1999 Warrior Problems
Ok I need help I have a 1999 warrior that keeps blowing the fuse when I turn on the light switch I have replaced the voltage regulator the switch and some wires what else could it be?
Need help quick!!!
Old Nov 13, 2007 | 03:04 PM
strike_fly's Avatar
you have a short. check the headlight assembly
Old Nov 14, 2007 | 03:55 PM
I do not have any head lights pluged in I thought that might be the probelm so I unpluged them still did it and then I even took out the wiring harness and clipped them off where they are split from 1 to 2 wires on the green yellow and black wires and it still does it! I guess I will have to go through each wire till I find the short but I was hoping there was a better way.
Old Nov 14, 2007 | 04:01 PM
strike_fly's Avatar
well i thought maybe you would get lucky and it be something easy. now you will have to trace each wire. that sucks
Old Nov 14, 2007 | 05:56 PM
Yeah tell me about it I was hopeing to get it fixed up to sell quick as I havn't rode it much since I had the motor rebuilt and got a set of spider tracks on it and I could use some extra cash for the holidays! But I will dig in and get it done!
Old Nov 16, 2007 | 07:05 PM
STRAIGHTUPDAHILL's Avatar
wire touching the handelbars inside the switch housing?
Old Nov 16, 2007 | 07:06 PM
wrong size fuse?
to high wattage bulbs?
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
kdg723
Jul 25, 2015 01:20 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
