electrical problem 2002 700
Old Nov 14, 2007 | 09:42 PM
CHIP6822's Avatar
Default electrical problem 2002 700
My 700 sportsman while running or idling with headlights on shuts off back fires then take off until quits . I can restart and run without lights on and works ok . Its charging 14 volts even with lights on . The ing switch was changes 2 years ago. I hope someone can give me a clue what to check for . Thanks
Old Nov 14, 2007 | 10:21 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Well my did the same thing!!!!!!............ECM!!!!!!!!!!!!!!!!!!!!!!!! !!!!
Question...........With the quad running without the headlights.........Does it shut-off once the lights are turned on???...........Mine did!!!!
Also do you need to turn the key switch all the way to the off position BEFORE starting again..............................If so ........ECM..........
There are two solid state circuit Breakers in there that provide protection for any overload that is detected!!!!!!!........If the ECM is faulty,or detects a fault, this will shut the quad down for saftey !!!!
My is a 2006 Sp 450 (all one unit).....Not too sure about the ECM on the 2002 models someone will tell you if the electrical breakers,rectifier,module may be separte units............Caper..........
Hope that helps..........
Old Nov 14, 2007 | 11:18 PM
trailbound's Avatar
I don't think the 2002 sp 700 has a similar ecm as the 450s and 500s.
Old Nov 15, 2007 | 09:54 AM
CHIP6822's Avatar
yes only have lights have been on for a while today took 2 minutes , you do not have to turn the key off but after a while the wrench flashes and it will run bad and backfire even with the lights on seem like after the battery is lower voltage
Thanks
skinnyr6
Aug 25, 2023 02:18 AM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
ranvette
Jul 4, 2015 06:13 PM
