Heated grips
Old Nov 27, 2007 | 09:10 PM
hkngoutdrs's Avatar
Default Heated grips
It's starting to get cold here in the midwest. I was planning on purchasing a seat of heated hand grips from Cabelas this week.
I have read alot of posts where guys are hooking them up to their head lights. When I take my pod off which wire (color) am I looking for?
Does anyone have a suggestion where to hook them up other that the headlights? It would be nice to have the heated grips when I don't feel like having the headlights on.
Thanks
Old Nov 27, 2007 | 09:11 PM
hkngoutdrs's Avatar
I should have said this, I have a 2007 Sportsman 800.
Thanks
Old Nov 27, 2007 | 09:17 PM
hoytultratec's Avatar
it will tell you in the directions that come with them.....but i do know i love my heated grips. you just need a hot wire it doesnt need to be the lights (i think) how about the accessorie plug could splice into that.
Old Nov 27, 2007 | 09:32 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I think Polaris has a ACC spare wires under the Pod ........They are listed in my Factory Repair Manual for my Sportsman 450(2006)..........I do believe..........Caper...............
Old Nov 27, 2007 | 09:57 PM
Mongrol's Avatar
"Official Site Skeptic"
My buddy has used just about every brand but swears that this is the best!
http://www.hotgrips.com/?gclid...lYfizo8CFQflhgod918Nzw
Old Nov 27, 2007 | 10:11 PM
Brainerdian's Avatar
The ATV winter pak from Cabella's (cheapest I found) is a very nice setup and I hooked mine up to the accessory wiring. It goes on and off with the key, doesn't require anything else (lights) to be on and there is plenty of capacity. Follow the directions exactly with the WD-40 and you won't have a problem (make sure you heat them up first too).
I love 'em for cool days in the fall set on low - for plowing set up a little higher and even to warm my hands on high in the evening after sitting in the deer stand all day.
The thumb warmer is a gotta have also.
Old Nov 27, 2007 | 10:37 PM
SCRAMMYTODD's Avatar
Personally I like the Pure Polaris grips. They stick to the bars themselves so you can put whatever grips you want over them. The switches are really small so they don't take a lot of room up on your pod.
As for the power wire, I went off the 12 volt plug in.
Old Nov 29, 2007 | 01:46 PM
hkngoutdrs's Avatar
Thanks for all the info. I checked out hotgrips and as fas as I can tell they don't sell a thumb warmer. It's a shame I do like the different styles and grips that they do carry.
Old Nov 29, 2007 | 04:07 PM
Hotdogmb's Avatar
I also have the Polaris hand and thumb warmer. Hooked to the acc plug. I also put the Polaris hand guards on. They keep your hands out of the wind and make them feel warmer. All I use is the low setting most of the time. They have worked fine for me, three winters now.
Old Nov 29, 2007 | 08:17 PM
Weber67's Avatar
Mine came with my wheeler, and I love them. Polaris factory installed, so I have no idea what wire they used. I would suggest you use a spare wire if available. The amp draw on high could be a little high to run of the lighting circuit, over time anyway.
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
black_thunder
Sep 7, 2015 01:24 AM
