do i need to split the engine to replace the crank seals
Old Dec 1, 2007 | 06:38 PM
wizard1212's Avatar
Default do i need to split the engine to replace the crank seals
Can i replace the crank seals without spliting the engine, or do i need to pull the crankshaft out of the housing? And if one of the seals are bad would that be the cause of the bike not starting due to bad seals?
Old Dec 2, 2007 | 12:22 PM
LT80's Avatar
LT80 Expert
They usually start but suck air and don't run right.
You've cleaned the carb and checked the reed (if it's a 2 stroke) and made sure there was spark. Right? [img]i/expressions/face-icon-small-smile.gif[/img]
The seals usually push in from the outside. No spliting.
Old Dec 3, 2007 | 01:35 AM
wizard1212's Avatar
The carb was cleaned twice i have not checked the reed yet. If i push the seals in they will go into the case the harbors the rod, the seals do not come out,n they have to be pushed in? Also the bike started on starter fluid once but not again.
Old Dec 3, 2007 | 01:36 AM
wizard1212's Avatar
Also if they push in how do u get them out to change them?
Old Dec 3, 2007 | 09:44 AM
LT80's Avatar
LT80 Expert
You pry them out with a pick, screwdrier, etc. [img]i/expressions/face-icon-small-smile.gif[/img]
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
TegraQuad
13
Nov 26, 2017 01:40 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
Ragtop
Jun 27, 2015 03:04 AM
Dabears1983
Jun 16, 2015 12:17 PM
