1996 300 xplorer 2 stroke...NEED HELP
Old Dec 2, 2007 | 06:01 AM
New2ThisForum's Avatar
Default 1996 300 xplorer 2 stroke...NEED HELP
i just got a 1996 300 xplorer 4x4 2 stroke, this is my first polaris. i got it home and was doing some visual inspections, popped the plastic off the right side, looking there i noticed a small gas line running from the bottom of the carb (just guessing, overflow) down to a nipple just above the dipstick on the transmission, deciding to drain the transmission i got mostly gas from it, probably 90%gas 10%oil. i'm really concerned about this, can anyone explain this? also what fluid can i use to put back in the transmission?
thanks, Greg
Old Dec 2, 2007 | 09:00 AM
big_kid's Avatar
sounds like someone put the overflow hose in the transmission vent....
Old Dec 2, 2007 | 10:00 AM
hoytultratec's Avatar
it shouldnt go from carb to the tranny overflow from the carb hooks to nothing.
Old Dec 2, 2007 | 10:06 AM
ftwflh's Avatar
The tranny vent runs up by the carb I would say someone put it on the overflow instead of the 2 hoses with the check
Old Dec 4, 2007 | 01:18 PM
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
The tranny vent runs up by the carb I would say someone put it on the overflow instead of the 2 hoses with the check</end quote></div>
Could you explain where the tranny vent hose runs to a little better so i'll know where to put it?
Greg
Old Dec 4, 2007 | 05:57 PM
ftwflh's Avatar
From the back of the tranny up by the bottom of the gas tank
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
chewy78
Sep 8, 2015 10:37 AM
