cutting plastic
Old Jan 9, 2001 | 07:29 PM
zeebo's Avatar
Does anybody know a good way to cut atv plastic without melting it ? I am talking about really thick plastic on a honda recon ? any replises ideas or anything would be greatly appritiated
Old Jan 9, 2001 | 07:35 PM
3wheelin's Avatar
USE THE EDGE OF A HAND GRINDER. MAKE SURE YOU TRACE YOUR LINE FIRST, AND BE CAREFUL
84 200X
85 250R, TRI-Z
86 TECATE
Old Jan 9, 2001 | 08:00 PM
ranchadozer's Avatar
if u wanted u could use 1 of those dremel tools i have a cordless dremel and i can put it on high(15,000rpm)with a cutting disc it would work,my dad has 1 with a cord and it gets 30,000 rpm,same as 1 of those dentist drils they put on my cavity today,ouch,but it should work
Old Jan 9, 2001 | 11:42 PM
RideRed04's Avatar
a dremel would work very nice, i just got one for christmas, but on low so you dont cut off something you dont want to. read this thread where i explain the one of the best ways to do it.http://forums.atvconnection.com/thre...rigpost=144366
Old Jan 10, 2001 | 05:57 PM
stuacald's Avatar
You can use a dye grinder to cut the plastic. Use tape to mark where to cut and go slowly. Aferwards use a sharpe razor blade to smooth out the edges the dye grinder left behind. I did this on my 300ex to make race fenders. It really does a good job.
Old Jan 13, 2001 | 03:29 PM
MX265X's Avatar
i used tin snips and then a DA sander w/ a 450 grit pad and it worked good but when we cut my friends we used a dovetail saw it was sooo much easier! then ofcourse the DA!
Old Jan 13, 2001 | 05:22 PM
BIGORANGE's Avatar
Good ole fashioned hacksaw or coping saw works for me.
Old Jan 14, 2001 | 04:17 PM
zeebo's Avatar
thanks for all the replies ! last night I tried to cut my fenders witha hack saw , it didnt work . then I tried a wizard( same thing as dremel tool) didnt work then I tried a jig saw witha course blade , didnt work . so iwent to bed pist . then I went down this morning and got out a rowder , that really was a bad idea . and last I got out the jig saw again and put on a fine tooth wobbly blade and it cut threw the thick recon plastic like nothing there was almost no sanding needed thanks again everyone!
Joe454
Nov 20, 2020 01:19 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
