high comp. 400ex starting problems
Old Dec 5, 2007 | 11:58 PM
rockroller's Avatar
Default high comp. 400ex starting problems
ok so, high comp. piston, hot cam, pipe jet, cdi box,... so the question is, dose anyone know if they make a kick start for the new 400ex, and or a heavyer starter to take away my headaches of starting it?or anyother secrets on easyer starting!?
thanks Junior
Old Dec 6, 2007 | 12:09 AM
ctateusa1's Avatar
bump up the battery for one thing, if they make a battery with more cold cranking amps it will make the bike turn over easier with the high compression piston and it will make it easier to start. Otherwise check your pilot jet to make sure it is putting enough gas in at the same time, and your fuel mixture screw.(I gotta do this on my bbk build on the wolvy as it is hard to crank with the stock battery when really cold, and doesnt want to idle till it warms up a little(probably the mixture screw on mine))
Old Dec 6, 2007 | 07:37 PM
rockroller's Avatar
thanks man! i'll be trying that. now dose anyone know were i can get a high torque starter for it?
Old Dec 8, 2007 | 01:00 PM
powerslider's Avatar
Try the stock cdi, some of the aftermarket cdi's cause problems starting in cold weather...
DTroyer01
Jul 3, 2015 07:34 AM
Big600twin
Jun 10, 2015 03:01 PM
garyt1975
Jun 5, 2015 08:53 AM
kevbowe
Jun 1, 2015 01:17 AM
1000gade
May 27, 2015 12:37 PM
