winch wiring problems
Old Dec 8, 2007 | 07:35 PM
mykmiller's Avatar
Default winch wiring problems
I used a tester to test ignition wires when key is on. The red black wire is hot only when key is on. However, when I connect the red wire from the winch controls, the winch does not work. I can take the red wire back to a solenoid (not winch solenoid) and the winch works. I cannot figure out why it will not work connected to red black wire. Anyone else use the red black wire?
Old Dec 9, 2007 | 12:30 PM
mykmiller's Avatar
Ok I got it figured out. The red and black wire is the correct wire to use. In the instructions for the Gorilla winch that came witht he winch, the wiring of the solenoid was incorrect. If you are wiring one up, make sure to get the instructions from their website. Just make sure you put the correct wire to the correct color coded bolt. I hate it when you get instructions that are wrong. Don't those things get noticed??
Ragtop
Jun 27, 2015 03:04 AM
TLC
Jun 21, 2015 10:02 AM
FWhitt
Jun 13, 2015 02:22 PM
wildbill59
Jun 9, 2015 02:28 AM
elpayaso
Jun 3, 2015 10:39 AM
