ignition issues
Old Dec 14, 2007 | 01:11 PM
hillbillyhottub's Avatar
Default ignition issues
Does anyone know if the ignitions in the Hensim Quads are an ongoing issue? We have had 1 machine, about 6 hours of riding and 2 ignitions, now the other machine is down too. Seems to be the same issue. Is there an aftermarket ignition that is better that we can put in after the warrenty exspires? Also, any information on the automatic transmissions on the 4x2 150? It jumps/clunks on us.
Old Dec 14, 2007 | 06:21 PM
Dennislinden's Avatar
K, hillbillyhottub, guessin' ign. switch got wet somehow? However there R aftermarket switches. just would have to be connected properly an easy conv. as far as your tranny problem goes not sure not enough info. & not sure on the machine..Dennis
Old Dec 16, 2007 | 06:17 PM
tthejackal01's Avatar
i have heard of the problems with the ignition and the water in it is correct and the best ting to do when you replace it with the new one is to seal the connections with a water resistant gel.as for the transmission problems the 150cc's have a cvt trans which are belt driven and the belts tend to dryrott and for that matter dry out all together over time and use as with all belts. the best thing to do is to check the belt and replace it if needed to and keep another one on hand for the future. there is nothing that will stop that wear on them, just replace and go again, thats part of having a CVT transmission.
Old Dec 17, 2007 | 03:58 PM
Thanks....The transmission issue has been since day 1 of having the machine. It has less than 6 hours driving time on it. It is back in the shop along with the 110 still under warrenty, but it is beginning to be a pain bringing them in, not having them for weeks, paying for labor to bring them home and have them break again. We are hoping to get them running ok then replace with aftermarket parts
Old Mar 2, 2008 | 10:49 PM
shsound1's Avatar
Hello Shawn here with a hensim 70cc, 1 week old, all of the sudden, you turn the key over and it just clicks, battery is full, any ideas?
Old Mar 6, 2008 | 11:10 AM
SilveradoSS's Avatar
Sounds like the battery. Is it fully charged?
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
