Can't remove oil drain bolt on 70cc Hensim?
Old Jun 7, 2007 | 03:15 PM
JustPlainBecky's Avatar
Default Can't remove oil drain bolt on 70cc Hensim?
We cannot get the oil drain bolt removed from the 70cc Hensim. Everything is set to go, but we have to get the shipping oil out...... but the bolt won't come off!
Has this happened to anyone else? Whats the deal? A ratchet wrench won't fit in there, the bolt is just against the frame bar...... trying a closed wrench now but anyone else have any ideas?
Old Jun 8, 2007 | 03:58 AM
Guest
Guest
Posts: n/a
try to heat up the bolt first. or tip the atv to 1 side and drain from the oil fill cap.
or use a oil extractor
good luck
Old Jun 9, 2007 | 10:55 AM
We ended up using an extractor.... still couldn't get that bolt off. We'll give it a go on the next oil change.... Thanks!
Old Mar 2, 2008 | 10:47 PM
shsound1's Avatar
Just did the same thing! I bought mine and just got it from Costco.com i removed the wrong one and a spring fell out! That was the crank case oil! Which was almost empty. So I undid the other one, which was the oil and it seems to be stripped, when I removed it, after getting the wrench in there at an angle, it came off with much force. Then gong on was very difficult.
I may return it, what do you think?
Shawn
Old Mar 6, 2008 | 11:07 AM
SilveradoSS's Avatar
I've read of other quads having this problem. I think what they did was loosen the engine mounting bolts and move the engine around until they could get a wrench on the bolt.
Old Mar 6, 2008 | 11:24 AM
shsound1's Avatar
Hello, Shawn here. Call me and I will explain the bolts, do not remove the wrong one! A spring will pop out
shawn 303-484-8237 ext 304
house1
Aug 9, 2015 10:49 PM
Bell21
Jul 28, 2015 06:52 AM
skeets44
Jul 17, 2015 01:04 PM
Desimation2k8
Jul 17, 2015 12:37 AM
Shifts
Jul 3, 2015 07:59 AM
