Honda 300trx 1992 Carb leak
Old Dec 14, 2007 | 04:56 PM
canuck420's Avatar
Default Honda 300trx 1992 Carb leak
Hello everyone,
I have a big problem with my atv. Whenever I let it sit fuel leaks out of the overflow in the carb. I have taken it apart numerous times and even took it to a mechanic but I still have the problem.
I am pretty sure the problem is that the valve is not seating into the carb body properly to shut off the incoming fuel. I have installed a new float and valve but still have the problem.
The only thing that I can think of doing now is to replace the entire carb body for $300 or take the carb to a machine shop and have it polished or machined.
Does anyone have any suggestions for me? I hope to hear from you.
Thanks,
Ryan
Old Dec 14, 2007 | 05:31 PM
joshjines's Avatar
u shut your shut off valve every night and maybe your float is stiking whene it is running dose it bog out alot
Old Dec 14, 2007 | 06:08 PM
canuck420's Avatar
Yes, I have to shut off the fuel every time that I am done with it. Sometimes it's hard to get started because its flooded. When I turn off the fuel right when I'm done it doesn't leak at all so it must be that valve.
Old Dec 14, 2007 | 06:19 PM
joshjines's Avatar
my atc used to do that alot i mean alot every day it did and i finnaly took it apart and there was something cloged in the needle valve that idels the gas to the carb got an idea take your carb apart once again lol and drain all the gas out than hold it up side down while holding the float down and blow threw the gas tube and if it blows threw you might need to adjust your float or get a new needle valve have you got a carb kit latly
Old Dec 14, 2007 | 06:51 PM
canuck420's Avatar
I have a new needle valve and float on it. When I blow through the gas tube no air comes out.... I also have a new carb kit in it
Old Dec 14, 2007 | 08:32 PM
joshjines's Avatar
sense althat is good its got to be or your shut of valve ive never heard of anything that bad
Old Dec 15, 2007 | 12:24 AM
Gimpster's Avatar
Ryan
Take off the primer assembly and check the diaphram
I have seen these go bad and leak fuel past them when sitting
Just went through the same thing as you have, I replaced the float valve, float etc... and it would not stop running over when sitting
My primer diaphram had a rip in it. Replaced it and no fuel has leaked since
----- Gimpster -----
Old Dec 15, 2007 | 02:21 AM
canuck420's Avatar
Alright Gimpster, you have a great point. I will check the primer diaphram....
Old Dec 15, 2007 | 02:54 AM
Gimpster's Avatar
I have to warn you that the replacement parts are around $70 so make sure that is the issue before spending the cash. Try one off a buddies carb first.
----- Gimp -----
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
