96 sp 400 front chain.
Old Dec 15, 2007 | 11:08 PM
hoytultratec's Avatar
Default 96 sp 400 front chain.
whats the secret on getting the chain on,im having a hard time getting it aronund the sprocket not much room between the sprocket and the frame.
someone has done it i hope...help
Old Dec 15, 2007 | 11:25 PM
ftwflh's Avatar
split the chain at the master link.
Old Dec 15, 2007 | 11:30 PM
it is , having a hard time getting it around the front sprocket its so tight between sprocket and the frame if it will go i will keep trying tommorow after work.
Old Dec 16, 2007 | 09:44 AM
ftwflh's Avatar
loosen the eccentric and roll it back away from the frame
Old Dec 16, 2007 | 04:07 PM
thanks for the help, i now see what to do and how it works the only problem is the bolt to loosen it the head is rounded (not by me) and cant get at the nut below just out of reach of the socket (doesnt line up with the big hole) so i couldnt get it loose i guess i will take it in let them deal with it.
thing that sucks is it was a new chain on there...guess i wont be plowing hard into snow banks anymore.
thanks
Old Dec 16, 2007 | 09:45 PM
ftwflh's Avatar
Dont give up try a few things first.like grinding the head off the bolt to get it out and replace it
Old Dec 16, 2007 | 11:40 PM
I might be able to get the sawz all and a metal blade inbetween and cut the bolt might take a while and a few blades will check it out this week.
STLyamwar
Jul 25, 2020 04:44 AM
U2OFlyer
Aug 5, 2015 12:46 PM
Zach509
Sport Quads
Aug 3, 2015 02:44 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
carolinabomb
Jul 26, 2015 08:40 AM
