clicking and no starting....
Old Dec 21, 2007 | 06:55 PM
scott66's Avatar
Default clicking and no starting....
Thought my battery was shot, as all the wheeler would do was click click , so I went and bought a new battery, noticed a fuse blown to. so I put in a new one of them to. but even with a new battery and a fuse, nothing but clicking. anyone give me any suggestions , that I could check befor taking it in. any help ,,, I would be greatly thankfull. my 4 wheeler is a honda rancher.
Old Dec 21, 2007 | 08:19 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
So it will start just fine with the recoil starter???? (Assuming it is a Rancher 350.)
Old Dec 21, 2007 | 08:48 PM
HondaMechanic's Avatar
Get a multi-meter set it on volts DC , put the red lead on the starter post (+) and put the black lead to a good ground (-) on the engine then push the starter button (with the key on) if it has 12V then you probably need the starter re-built (new brushes) ...
Old Dec 21, 2007 | 08:53 PM
Gimpster's Avatar
Starter brushes are bad.
Try turning on the key, hold the starter button while tugging on the pull starter. If the starter takes off, for sure the brushes are bad. Same thing, only tapping on the starter while holding the starter button, if the starter takes off, brushes are bad.
----- Gimpster -----
Old Dec 21, 2007 | 08:55 PM
Gimpster's Avatar
Dang, Hondamechanic, you just barely beat me to the punchline...hehehe
That's what I get bs'n with the woman while I'm typing
Old Dec 22, 2007 | 10:11 AM
scott66's Avatar
yes it will start , with the pull start.
Old Dec 22, 2007 | 10:17 AM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: scott66yes it will start , with the pull start.</end quote></div>
Then at least you can still ride until you sort out the problem!
Old Dec 22, 2007 | 10:33 AM
scott66's Avatar
If it starts with the pull cord, which I found last night ,and it started on the first pull, then after it started I shut it off, now it starts with the push button. Is there something I should get looked at or change as I dont want to get stranded in the middle of lake winnebago.... yes at least it starts with the pullcord but I definitly want it to start with the button.
Old Dec 22, 2007 | 10:57 AM
Red Rider
Sounds like it charged up the battery while it was running. Maybe your new battery just hasn't taken a full charge yet???
Why the fuse blew is another issue! The lights and starter are on the fused circuit.
Old Dec 22, 2007 | 11:52 AM
Red Rider
Batteries are overrated anyway. My 450R has no battery at all, and I don't miss it one bit!
