400ex top end problems
Old Dec 22, 2007 | 05:21 PM
bams400's Avatar
Default 400ex top end problems
i just purchased an 02 400ex. the guy i bought it off of said it needs rings but im not sure. it sat for a good while and when i got it started it smoked really bad. i changed the oil in it and cleaned the carb. i also took the exhaust off and cleaned it out then checked the plug it was good. after all that it still smoked really bad. then i started it another time and the exhaust turned cherry red along with the smoking. does anybody have any suggestions?
Old Dec 22, 2007 | 06:04 PM
go-hard-or-go-home's Avatar
If the exhaust turned red its getting to much gas, like the choke is stuck. I would for sure put some new rings in it if its a factory 02. Also check your valve seals. Thay could have dry rotted from sitting.
hope this helps
Old Dec 22, 2007 | 10:43 PM
hondabuster's Avatar
Hows the compression? If its still good, the rings proabably are too.
The red pipe comes from either too much time idleing...or a lean idle mixture. Did you check the pilot jet when the carb was apart...its probably partially blocked, or the mixture screw is screwed in too far.( It should be about 2 turns out, or more.)
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
