400ex front brakes
Old Dec 23, 2007 | 10:19 PM
Troys40ex's Avatar
Default 400ex front brakes
I have a 99 400ex and my front brakes suck I am looking for some way to improve them
Old Dec 24, 2007 | 01:05 AM
hondabuster's Avatar
Do you get a firm feel from the brake lever...or will it go to the handgrip?
Youve probably got a froze caliper pin. Even with stock pads, with good traction and tires, you should be able to just about do a stoppie.
Pads wearing even ....Inside and outside? They should wear very close to evenly.
Remove both calipers, and make sure the caliper can slide on the 2 pins, which hold it to the mounting bracket. It should be very easy to do by hand, and if not, youll need to disassemble and relube those two pins.
You could also have a low master cylinder, or air in the system. If you havent done it yet..now is the time to flush, fill, and bleed the brake system.
Old Dec 24, 2007 | 02:09 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Those are great brakes. If you have a problem, it isn't because they are poorly designed. Mine are 10 years old, and still great.
Get a service manual, and go through the trouble shooting section for brakes.
Old Dec 24, 2007 | 11:38 AM
Troys40ex's Avatar
Thanks
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
95wolv
Jul 21, 2015 12:25 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
yambam13
Jul 4, 2015 01:49 PM
