Primary Clutch Sqweek
Old Dec 24, 2007 | 10:06 PM
02magnum500's Avatar
Gets his share of deer.
Default Primary Clutch Sqweek
Ok, with my 2004.5 sp 500 HO there is a sqweeking sound comming from the primary clutch. The noise only occurs in the winter when it is idling while the engine warms up. After the machine has been ran a while the noise is for the most part gone. I would say that you can hear the sqweeking sound about 25 feet away so it is kind of loud. It must be comming from the primary clutch being it only makes the noise at idle. This noise was happening last winter but it was not as loud. 223hrs, 1355miles clutch cover has never been off and motor mounts are ok. Any idea's? Thanks in advance.
Old Dec 24, 2007 | 10:58 PM
1smokin50's Avatar
Probably the belt rubbing on the primary clutch, just like in a car... cold weather!! LOL!! Brings out all the little noises.....
Old Dec 25, 2007 | 09:58 AM
ftwflh's Avatar
Try a new belt.While you have the cover and belt off start it and see if the noise is still there
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
