cranks but wont stay running
Old Dec 30, 2007 | 04:35 PM
sleeper1969's Avatar
Default cranks but wont stay running
ive got an 2004 arctic cat that has developed a problem. it will crank but just as soon as it gets started it will go dead.ive checked the carb and it is ok nice and clean.when i give it gas it goes dead. tried new battery but same results. new gas also, no go. any ideas??
Old Dec 30, 2007 | 11:47 PM
mudslinginfool's Avatar
Does it in the Mud!
check the spark plug and make sure the gap is correct. air box clean of debre? couple easy things to try.
Old Jan 7, 2008 | 06:31 PM
ok,air box seems clean and i am going to replace sparkplug just to be safe.(it was black around end).i noticed though that when i took the plug off that the top of the plug has a treaded top instead of a regular cap like in a car... is that normal?
Old Jan 14, 2008 | 01:01 PM
25083's Avatar
Usually if your plug is black, you are running too rich. My V2 does the same thing and I'm trying to get it start and run properly. That is normal for the threaded plug connector, a lot of bikes are like that.
Old Jan 14, 2008 | 08:26 PM
Does it in the Mud!
well, whats the verdict? is it fixed?
Old Jan 14, 2008 | 10:42 PM
its cranking with the pull crank better now but when i try to use the push button it just clicks.im going to try a newer battery and check out the starter to make sure its engaging correctly.on the running to rich part? how do i correct that?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
cbcole02
Sep 7, 2015 06:16 AM
jayking232003
Jun 9, 2015 02:54 PM
