buying a plow
Old Jan 10, 2008 | 02:30 PM
andrewallen's Avatar
Default buying a plow
Hey guys. I have an 03 arctic cat 400 4x4 i was going to buy a plow for it and i was wondering if anyone knew how high the plow lifts off the front because i want to see if it will go up onto a trailer with the plow on. thanks
Old Jan 10, 2008 | 03:01 PM
Chumley's Avatar
Depends on the incline of the trailer. You may have trouble if you are using a tilt bed snowmobile trailer, but if you are using something lower then you should be fine.
Old Jan 12, 2008 | 08:22 PM
weez440's Avatar
the plow on my 650 lifts really high actually. i am sure it would clear a tiltbed snowmobile trailor. if not just give it more gas [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 19, 2008 | 02:20 PM
mountainclimber's Avatar
i have 8 inches fron the ground to the wear bar for the plow. I use my winch to lift the plow as of now. Previously I used the maunal lift (hand lift) and only had about 5-6 inches. Also tightinging the front suspention to the highest setting helps with the clearence. hope this helps
Erick J. Edler
Aug 29, 2015 01:32 PM
readymixer169
Aug 21, 2015 10:05 AM
Gtsordo
Jul 22, 2015 01:27 PM
Gtsordo
Jul 13, 2015 10:38 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
