Smaller brake levers??
Old Jan 15, 2008 | 01:42 PM
TarHeel1's Avatar
Default Smaller brake levers??
I bought my daughters some atvs. my youngest daughter has a hard time reaching the brake lever (she can but not as easy as I'd like). Do anyone know where I could find some levers that are made for smaller kids or come in toward the grip more??
any info is appreciated!
thanks
Kyle
Old Jan 15, 2008 | 01:49 PM
Chopper400ex's Avatar
You can heat up the one you have and bend it in. Take it off and put it in a vise, and heat it up with a torch. Get it really hot before you start bending.
Old Jan 15, 2008 | 02:18 PM
DAMONSQUAD's Avatar
if its a single cable you can prob make a bicycle brake lever and perch work
Old Jan 15, 2008 | 03:15 PM
TarHeel1's Avatar
good ideas guys thanks. I had thought about the heat but wasn't sure it it would work or not.
Old Jan 15, 2008 | 10:35 PM
oldyeller's Avatar
Take a look in my pictures and you will see a very simple little modification I did to our viper..It's just a piece of metal that holds the lever closer to the bar.I just had to loosen the brake cable adjustment so the brakes weren't dragging and readjust...The nice part is its totally reversible so you can just remove the bracket once they get bigger.
Old Jan 15, 2008 | 11:29 PM
dwhst9's Avatar
We just put a large zip-tie between the lever and perch, right around the cable. Re-adjust brake cable as necessary.
Old Jan 16, 2008 | 11:26 AM
TarHeel1's Avatar
Thanks everyone for the ideas!
oldyeller - I have some strap metal like you used and will try it out!! Good pic!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
tysonbully
Sep 28, 2015 02:30 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
