04 400 Rancher AT Shifting problem
Old Jan 24, 2008 | 07:38 AM
steve58's Avatar
Default 04 400 Rancher AT Shifting problem
After a good search I cant find any info on my problem. The quad will only shift into FWD and REV with the selector level. In FWD it will not shift out of 1st.
The ESP /AUTO switch on the right handle bar does nothing. When the switch is on ESP the shift motor is silent, I checked the fuses, there OK, Anybody experience this problem before?
Steve
Old Jan 25, 2008 | 07:50 AM
steve58's Avatar
OK , so Im up and running and shifting again. Turns out to be a simple fix, evidently a branch/stick had found its way from the rear up to the shift motor on the left side under the silver plastic engine side cover and knocked one of the wires off the shift motor.
The clean, shiny, exposed contact was very visable after removing the side cover. The wire end was somewhat damaged so I had to squeeze it with a small pair of pliers to make it stay on tight.
Steve
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
sara durrant
Jul 6, 2015 05:32 PM
