scrambler rear brakes
Old Jan 24, 2008 | 09:27 PM
diesel350's Avatar
Default scrambler rear brakes
my scrambler rear brakes don't work good with the foot pedal.Blead the brakes a 1000 times.Every thing works fine with hand brake.my sportsmans foot pedal locks the wheels up when you just touch it.anyone have ideas?
Old Jan 24, 2008 | 10:21 PM
SCRAMMYTODD's Avatar
Mine worked for about 6 months and then they quit. I never bothered with them as the hand brake works just as good.
Old Jan 24, 2008 | 10:40 PM
1smokin50's Avatar
Gotta love the rear brake action on these things....or shall I say the lack there of!!! I'm planning on re-doing mine this spring!!! I like the rears for trail ripping!!!
Old Jan 24, 2008 | 10:43 PM
Indslpwr04's Avatar
MIne were that way for years till i took apart the caliper and found the bolts that haold the 2 halved were loose. The gaskets were not sealing which let the pressure bead off. You can try taking the caliper apart and cleaning it. Mud gets inside and lossens every seal.
Old Jan 28, 2008 | 09:34 PM
diesel350's Avatar
I rebuilt my rear caliper and the foot brake still sucks.What's a good brake pad to use?I been using polaris brakes is there a better one to use?
Old Jan 28, 2008 | 10:01 PM
Indslpwr04's Avatar
Its not the pads. I think the peddle assembly is a junk item. I have in the past had an emergency where i had to switch the lines on the rear caliper because the seal blew out on the main system. Switching the lines isolated the blown seal to the peddle system and the good side of the caliper to the f/r combo system.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
DeFox500
Jul 26, 2015 06:32 PM
timster911
Jul 13, 2015 01:57 PM
