Will a raptor Edelbrock Carb Fit a Warrior
Which raptor are you talking about?
Raptor 350 and warrior edelbrocks are the same with the exception of the manifolds.
Raptor 660 carb is completely different, and wouldn't come close to working right.
Why not just buy an edelbrock FOR the warrior instead?
You can feel that way, but I actually know the facts. The edelbrock carbs are the same, the boot is different simply due to different length and angle between the head and airbox. The stock vs stock is different because the raptor 350 uses a larger carb than the warrior, actually pretty much the same carb that's on the z400. Why would edelbrock have redesigned the carb for the raptor 350 when the warrior and raptor 350 have the same engine? Wouldn't make sense, would it?
The why was there was one for a raptor 350 on ebay cheap (used) I am assuming there would have to be mods made to make it work. I let it slide anyway. Are the Edel's and or the Keihin FCR worth the money or would a good mikuni 38mm flatslide be just as good or better? Going up to the 38mm and going from CV to flatslide would be better??? Aren't the Edel's and FCR's still CV carbs?
