TIE ROD
Old Jan 27, 2008 | 08:37 PM
rhonda350's Avatar
Default TIE ROD
i waz out on da trail today and i waz going around 40mph then there was this big *** bump i tryed to avoid it but my right tire hit it i heard something pop or snap then i got of and saw i broke my tie rod its just the end peace that i broke i went to honda and got me a new tie rod end when i got home i tried to get the tie rod end off but it wont move i tryed again but it still wouldent move the tie rod is a screw on screw off i mean that u twist it off and on wat u think i should do before i spend lots of money at honda to repair it i have a 350 rancher
Old Jan 27, 2008 | 08:44 PM
joshjines's Avatar
Default TIE ROD
use wd-40 and beat it off break it off or something sense it is bad anyway just brake it off JUST KEEP TRYING SORRY COULDNT BE MORE HELP
Old Jan 27, 2008 | 09:57 PM
JeffinTD's Avatar
Default TIE ROD
Are you meaning that you can't get the tie rod end off the tie rod, or is it the stud part that won't come off?
If you mean getting it off the tie rod, you will need to use two wrenches to break the lock nut free, and one side is left hand thread.
If you are talking about the stud part, once the nut and cotter pin are off, you may have to pry or smack it a little. Removing the inner fender might make access easier.
Old Jan 27, 2008 | 10:46 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default TIE ROD
Keep in mind also that one end of the tie rod is regular thread and the other is reverse thread.
Old Jan 27, 2008 | 10:56 PM
rhonda350's Avatar
Default TIE ROD
<div class="FTQUOTE"><begin quote>Originally posted by: JeffinTD
If you are talking about the stud part, once the nut and cotter pin are off, you may have to pry or smack it a little. Removing the inner fender might make access easier.</end quote></div>
im trying to get the tie rod end off the tie rod
and the other peace to that connects to the tire it looks like a ball
Old Jan 28, 2008 | 12:33 AM
JeffinTD's Avatar
Default TIE ROD
Then you just need one wrench on the square section of the tie rod end, and another wrench on the lock nut to loosen the lock nut before you can thread the joint off the tie rod.
I think it's the innter joint that's left hand thread, but look at the threads to be sure you are reefing on it the correct way.
Old Jan 28, 2008 | 12:51 AM
rhonda350's Avatar
Default TIE ROD
I think it's the innter joint that's left hand thread, but look at the threads to be sure you are reefing on it the correct way.</end quote></div>
the thing is that it wont come off its like stuck or something
Old Jan 28, 2008 | 12:56 AM
JeffinTD's Avatar
Default TIE ROD
The lock nut will be tight. It might be easier to take the cotter and bolt of the other tie rod end, and remove the tie rod from the machine.
Old Jan 28, 2008 | 01:03 AM
rhonda350's Avatar
Default TIE ROD
The lock nut will be tight. It might be easier to take the cotter and bolt of the other tie rod end, and remove the tie rod from the machine.</end quote></div>
i just dont want to strip the tie rod end peace trying to get it off
Old Jan 28, 2008 | 03:06 AM
JeffinTD's Avatar
Default TIE ROD
Just make sure you are positive which way the threads are on the one you are taking apart.
Worst case, the tie rod isn't that expensive...
BTW, what year is your machine? Was it part of the tie rod end recall?
