switches
Old Jan 27, 2008 | 09:12 PM
800rider's Avatar
Default switches
I want to put rear work lights and the reverse override lock on my 08 sportsman 800. what is the best way to cut out the templates on the back of the headlight pod
Old Jan 27, 2008 | 09:15 PM
700 sportsman's Avatar
Default switches
i used a toggle switch with a water proof rubber cover/nut
i mounted it underneath the pod on the left side so its out of the way
i got the switch at napa but any parts store should have one
Old Jan 27, 2008 | 09:16 PM
brutus450's Avatar
Default switches
personally, i would use a dremel tool to zip out most of it and then a sheetrock knife to clean up the edges and make the corners
Old Jan 28, 2008 | 02:03 AM
sheepdogMSP8117's Avatar
Default switches
<div class="FTQUOTE"><begin quote>Originally posted by: brutus450
personally, i would use a dremel tool to zip out most of it and then a sheetrock knife to clean up the edges and make the corners</end quote></div>
That's exactly what I did, worked great, very easy to do.
Old Jan 28, 2008 | 08:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default switches
<div class="FTQUOTE"><begin quote>Originally posted by: 800rider
I want to put rear work lights and the reverse override lock on my 08 sportsman 800. what is the best way to cut out the templates on the back of the headlight pod</end quote></div>
sent a pm to your question.
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
toonces
Sep 5, 2015 01:14 PM
