From warn 2.5 to rt25
Old Jan 30, 2008 | 09:11 PM
noooooo's Avatar
Default From warn 2.5 to rt25
I have a "Polaris" Warn 2.5 ci that I took off of my 05 800. When I put the rt25 in the same mount I had to use the other set of holes to move the entire winch about 1 3/4" to the right (as sitting on the seat) to get the front bumper to line back up. Just FYI. Learn from my mistake.
Old Jan 30, 2008 | 09:49 PM
brutus450's Avatar
the RT25 is a center drum winch, while the 2.5ci is offset winch
Old Jan 31, 2008 | 08:36 AM
JCDEYO25's Avatar
Good info.......
John
Old Jan 31, 2008 | 09:40 PM
SpudRacer's Avatar
So if I move my new "Polaris" Warn 3.0ci from the front to the rear to install a new Warn XT30 on the front, am I going to run into the same problem? I'd rather learn from other's mistakes than make my own...
Tom
Bryson City, NC
Old Feb 1, 2008 | 01:12 PM
noooooo's Avatar
Yes, its not really a problem though. There should be 4 other holes about 1 3/4" to the right of the current 4 holes the ci is bolted to on the mounting plate. Just use those holes and you wont have to take it back apart because the bumper wont fit like I had to. Just trying to save you guys a few minutes of disassembly then reassembly. Yes as stated above the rt/xt are center spool and the ci/ce are side spool.
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
