help 06 500 h.o. says its hot
Old Feb 2, 2008 | 02:59 PM
brindley's Avatar
Default help 06 500 h.o. says its hot
I need some help with a 06 500 ho .. as soon as you start it, it imediatly says its hot and the fan will not shut off even after you turn it off i will run forever...
I did some reading and it appears there was a ecu's that go bad is there a way to verify this so i dont go out and buy a part thats not bad..
I know there is a temp sensor on the engine is there one on the radiator i could not see one.
does anyone know what the oems are supose to be for the temp sensor so i can go buy a resistor to bypass it to make sure that is not the problem....
or if there is a data base that i could plug the numbers in and see if there is a recall for it...
Thanks in advance
Brindley
Old Feb 2, 2008 | 06:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
first thing its not the ecu, its the ecm that is bad. they had a recall on some of them for that year so take the vin number of the bike to the dealer and he can check on it for you. im betting that is whats wrong w/it like a few others have had for issues.
Old Feb 5, 2008 | 07:46 PM
brindley's Avatar
why would this have a ecm it does not have fuel injection what not are you refering to the cdi? i had the dealer run the vin and they claim they have never heard of the problem.but i would hate to buy a couple hundred dollar part for it not to be the problem thanks Brindley
Old Feb 5, 2008 | 08:01 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
It is I am on my third one for my Sp 450 (2006) and my is not EFI..........They control all the stuff you listed.............My fan was running without the key even in the quad..............And the first one the motor would shut off when the headlights were turned on!!!........99.9% sure ...That's good odds!!!!!!!..Caper........
Old Feb 5, 2008 | 08:02 PM
I did them both myself if you need to find it!!......Caper.........
Old Feb 5, 2008 | 08:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the emc(electronic modual control) not the cdi or the ecu is what controls voltage from the stator w/ along w/ dozens of other functions as caper as said. if the dealer hasnt heard of the recall on certain year and models then he must not have had that many sold as their have been a few out there. imo i think its what it is but couldnt tell you 100 %.
Old Feb 5, 2008 | 08:14 PM
trailbound's Avatar
search "surefire"module on here. I think thats what Polaris calls the part now.
Old Feb 5, 2008 | 08:21 PM
Or surepower module......................Caper...........
ltrmc02
Jul 22, 2015 04:50 AM
fourlix
Feb 1, 2001 11:30 AM
fourlix
Nov 26, 2000 04:39 PM
ms15
Sep 21, 2000 09:49 AM
