Prop-Shaft U-Joint #s
Does anyone know The Neapco U-joint part numbers That will replace the Polaris U-Joints? Polaris # is: (1590256 at 54 Dollars each. I Would rather pay more like 12 dollars each. Thanx Rise'em Hard Polcat
i know you dont have to pay 54$!! my local dealer also sells new holland farm equip. and the pto shafts match up perfect and they are 10$ a piece!! any farm equip. dealer should be able to help!! if not email me back and maybe i could get you a part # for you to use! hope i have been a help!
remember these are new holland u joints!! is there an equip dealer near you?? maybe a deere or case ih dealer could cross reference from the new holland #. what is your machine and what u joints do you need?? if you cant find a dealer maybe iw ould be worth your time to have me ship them to you if you are willing to wait a while! let me know. ryan
Greg, thanks, I was needing those NEAPCO U-joint numbers too. I am also looking for the NEAPCO BRAND U-joint Numbers for the prop shaft. (drive-shaft between the tannny and the front differential)Both ends of the prop-shaft u-joints are the same.
I have a bent prop-shaft,( A friend's machine 2000 400 xplorer )Polaris dealer in Tulsa wants 140.00 for the shaft and 54.00 each for the u- joints. I'm gonna have the shaft beefed, so it won't bend again for around 60 bucks at the local machine shop. I'm going to cross the dimensions of the U-joints and go back with NEAPCO.(10-12 bucks each) Polaris uses NEAPCO also, but The Polaris dealer is getting the middle-man cut.(54 bucks). The Napa brand u-joints haven't held up for me (rear-replacements, '98 model SP's). They have broken on several of the Quads that I ride with and also on the ones that I have worked on.
Finally, I would like TO THANK EVERYONE for their input... All Suggestions are welcome! Ride'em hard Polcat
