Prop-Shaft U-Joint #s
Old Jan 14, 2001 | 11:08 AM
polcat2's Avatar
Does anyone know The Neapco U-joint part numbers That will replace the Polaris U-Joints? Polaris # is: (1590256 at 54 Dollars each. I Would rather pay more like 12 dollars each. Thanx Rise'em Hard Polcat
Old Jan 14, 2001 | 07:16 PM
Traildog's Avatar
I have the part#s but they are on my other computer, which is at the docs for some work. If nobody supplies these numbers for you by the time my computer is fixed I will get them for you, probably Mon or Tues.
Old Jan 14, 2001 | 09:06 PM
rpaske's Avatar
i know you dont have to pay 54$!! my local dealer also sells new holland farm equip. and the pto shafts match up perfect and they are 10$ a piece!! any farm equip. dealer should be able to help!! if not email me back and maybe i could get you a part # for you to use! hope i have been a help!
Old Jan 14, 2001 | 10:23 PM
mnmag's Avatar
I sure would be interested in the $10-12 U-Joint part numbers. Please post as soon as possible
Old Jan 14, 2001 | 10:39 PM
rpaske's Avatar
remember these are new holland u joints!! is there an equip dealer near you?? maybe a deere or case ih dealer could cross reference from the new holland #. what is your machine and what u joints do you need?? if you cant find a dealer maybe iw ould be worth your time to have me ship them to you if you are willing to wait a while! let me know. ryan
Old Jan 15, 2001 | 08:21 PM
gregsims's Avatar
SP500 Rear U-Joints ar Neapco 1-1275 and 1-1875
Old Jan 15, 2001 | 11:43 PM
polcat2's Avatar
Greg, thanks, I was needing those NEAPCO U-joint numbers too. I am also looking for the NEAPCO BRAND U-joint Numbers for the prop shaft. (drive-shaft between the tannny and the front differential)Both ends of the prop-shaft u-joints are the same.
I have a bent prop-shaft,( A friend's machine 2000 400 xplorer )Polaris dealer in Tulsa wants 140.00 for the shaft and 54.00 each for the u- joints. I'm gonna have the shaft beefed, so it won't bend again for around 60 bucks at the local machine shop. I'm going to cross the dimensions of the U-joints and go back with NEAPCO.(10-12 bucks each) Polaris uses NEAPCO also, but The Polaris dealer is getting the middle-man cut.(54 bucks). The Napa brand u-joints haven't held up for me (rear-replacements, '98 model SP's). They have broken on several of the Quads that I ride with and also on the ones that I have worked on.
Finally, I would like TO THANK EVERYONE for their input... All Suggestions are welcome! Ride'em hard Polcat
Folger
Dec 8, 2004 06:04 PM
Hunter425
May 12, 2003 12:34 PM
Northstar2
Mar 10, 2003 11:01 PM
V8s10
Jan 7, 2003 07:56 AM
