saggy front end and tire clearence
1)Hey i have a 99 Bayou 300 4x4 and i have noticed that the front shocks are very loose and that front ends sags down easy... what can i do to help prevent this?
2) Can i clear 12" wide tires in back and 10" in front without hitting the shocks or muffler? Thanks
Question # 1: Replace springs/shocks. About $ 500 list for one pair, I'm afraid--get Y2k or later part number (available from parts catalog at www.buykawasaki.com) replacements; cushier spring rate and shock valving.
Tree Farmer
Tree Farmer
10" tires will rub up front. You'll have to replace stock lugs with longer bolts and space the wheels out about 3/8 - 1/2 inch. 12's will rub the rear shocks, but only under hard cornering and just enough to take the paint off your springs. Tree Farmer is correct- go for specs matching 2000 models for better results. Be ready for a new feel up front. Making your front end wider will add quickness and sensitivity to your machine's steering characteristics. This is not necessarily a good thing at high speed or on hard-pack surfaces.
JackTheKing
Jul 14, 2015 09:09 PM
