need Torque spec front hub
Old Feb 13, 2008 | 04:26 PM
rammey2000's Avatar
Default need Torque spec front hub
I need the torque spec for a front hub nut on a 2002 scrambler 400 4x4?? anyone help?
Old Feb 14, 2008 | 01:34 AM
03scrambler500's Avatar
Torque the spindle nut to 160-170 inch lbs. while rotating hub continuously. Back nut off 1/2 turn. Rotate axle several revolutuions by rasing rear of ATV and rotating rear whels with the machine in gear. Re-torque hub nut to 108-144 inch lbs. This is right from the service manual. Make sure you also have all of the bearings coated with the hub fluid before instalation so you get a accruate torqre. Hope this helps.
Bratman2
Aug 6, 2022 01:42 AM
carolinabomb
Jul 26, 2015 08:40 AM
TLC
Jul 25, 2015 02:24 AM
Unzzy66
Jul 11, 2015 10:01 PM
tporath
Jul 11, 2015 12:31 PM
