420 rear spring help
Old Feb 16, 2008 | 01:55 PM
sac7000's Avatar
Default 420 rear spring help
Unlike my old Yamaha the rear shock on my 07 Honda 420 is not adjustable and feel it's tad too soft. I'm a big guy and do most of my riding on gravel or improved dirt roads. I'd like to stiffen up the rear spring a bit to compensate for my larger girth but I'm not quite ready to jump into a set of new lift springs.
Is there a commercially available spring spacer or can I fabricate something that will keep the spring from compressing easily?
Old Feb 16, 2008 | 08:38 PM
Gimpster's Avatar
Moose makes a spring wedge kit. It twists into the springs. I put a set in the front of my 450es so the front would not sag with the snow plow on.
Here is a link where I found them spring wedgas It may be what you are looking for. Easy to install
----- Gimpster -----
Old Feb 16, 2008 | 10:40 PM
sac7000's Avatar
Thanks much! They should do the trick nicely. I don't need much, just a enough to help offset my larger then normal **** and equipment box I have mounted on the back rack.
Old Feb 16, 2008 | 11:08 PM
Gimpster's Avatar
I installed mine in the middle of the spring then spun them down into the tighter end of the coils, works sweet
----- Gimp -----
Old Feb 16, 2008 | 11:48 PM
sac7000's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Gimpster
----- Gimp -----</end quote></div>
Good tip, I would have never thought of doing that. Thanks!
Old Feb 17, 2008 | 02:11 PM
tramp's Avatar
I went with the high lifter springs. Increases weight cap. by 100 lbs. Same here on the sagging, with a plow on front and weight for traction on rear, the springs would sag terriblly.
Old Feb 17, 2008 | 05:24 PM
Gimpster's Avatar
How much did the springs lift the front of your quad with the plow off ? I think my springs are sagged. Might look into the highlifters
----- gimpster -----
Old Feb 17, 2008 | 08:53 PM
tramp's Avatar
About an inch, Gimpster. Before when I would lift the plow it would sag almost 4-5 inches. Now it hardly sags when plow is lifted.
merryman
Jan 19, 2016 04:29 AM
brinkkl2000
Oct 16, 2015 11:08 AM
Polaris5
Aug 29, 2015 09:11 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
