NEED HELP WITH EPI HIGH LIFTER CLUTCH KIT. 04 SPORTSMAN 700
Ihave a clutch kit that i bought several months ago from high lifter and i have lost the directions to it. i have a new helix which i know where that goes. i have one purple spring. one black spring and a white spring and some weights. can someone with any experience tell me what spring to put where? i am running 26" swamp lites on it. i want it to engage a little later than stock but not neck snapping. i do alot of trailriding and fairly steep inclines. thanks
Well you have one secondary spring and that goes in the secondary with the helix. You have 2 primary springs one will have more stall than the other,you will probably want to try both and see which one you like best. The primary spring goes in the primary clutch along with the weights. Just a heads up if you have the outlaw super duty kit made by HL it will be neck snapping and is not really trail friendly. I took my HL kit out and went with a heelclicker which in my opinion is the best kit for a Polaris sportsman.
KimSJoh
14
Jul 18, 2015 07:20 PM
