Polaris 2006 500 stalling out??
Old Feb 23, 2008 | 03:05 PM
GDeputy's Avatar
Default Polaris 2006 500 stalling out??
My friend's sportsman 500 stalls out when he starts it, shortly after anyways.
He says the RPM's will fluctuate betrween 800-1200 and it stalls out, putters is the word he userd prior to it stalling out, anyone have any ideas?
Old Feb 23, 2008 | 04:23 PM
mikdxer's Avatar
Tell him to try adjusting the throttle cable tighter up near the the grip, if there's to much slack in the cable the machine will stall out on you. I also had a problem with my idle speed screw backing off due to vibration and the idle would drop way down and stall. Mine is carburated.
Old Feb 23, 2008 | 05:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it an efi or a carb.? if its a carb turn up the idle a little. shouls idle around 1100 rpms. make sure there is abput 1/8" play in the throttle.
Old Feb 23, 2008 | 05:48 PM
RickTheStick's Avatar
If it is carb'd....check the Pilot Jet. Mine was clogged, could start, wouldn't idle but could rev' up and run fine...just wouldn't idle. The hole in the jet is so small that a standard sewing needle was too big to open the hole back up.
I have also seen a video from the nice folks at Cottonwood Motorsports in AZ that describes how a machine will die if there is too much slack in the throttle cable. The specs are between 1/8" and 1/4" play in the thumb throttle before it catches and rev's the engine. Good luck! I just got back from riding the 500. What a blast and the AWD....(grinning) just leaves the rest stuck in the mud!!!!
Old Feb 23, 2008 | 05:50 PM
most honorable master (Stendori) [bowing] Listen to the guy, he really helped me out on all of my issues!!!!
Old Feb 23, 2008 | 08:01 PM
sheepdogMSP8117's Avatar
Who's this Stendori guy?
Jmuddin284
Jan 19, 2026 07:16 AM
papahouse
Jul 28, 2015 12:42 PM
hondarider1234
Jul 21, 2015 11:53 PM
Gtsordo
Jul 13, 2015 10:38 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
