Reverse, 4WD and shifting problems...
Old Feb 24, 2008 | 09:51 PM
stpi's Avatar
Default Reverse, 4WD and shifting problems...
Hi, I have a 650 Rincon.
Since yesterday I have a problem with it : it doesn't stay in 4WD mode, it goes bad on reverse and doesn't want to shift higher than second gear ! "D" symbol deasapears and "ESP" flashes... Also the 4WD icon flashes.
All this happened at the same time. It was working fine last weekend.
When I turn the key off and restart the machine, everything seems to work fine : "D" icon is back, 4WD icon doesn't flash, 4WD is back and works fine and reverse works fine also.
As soon as I start to go fast, looks like its when it shifts in second gear, the trouble is back : 4WD turns off and it doesn't want to shift to higher gear. Everything start to flash on the display again. If I try reverse again, it works bad...
I turn the key off again and restart the machine, everything is fine again !
Can you help me ?
Thanks
95wolv
Sep 27, 2024 12:00 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
