trailboss leaking gas
Old Feb 24, 2008 | 11:48 PM
vinman18's Avatar
Default trailboss leaking gas
so awhile ago i put my 4wheeler away, and i took out the battery and turned off the gas and ran the atv till all of the gas was out of the carb. well today i put the battery back in and turned the gas on and when i turned it on, gas started leaking out, at a fairly fast rate. i looked and it seamed to be coming from the bottom of the carburator. so i took the seat off and looked at the carb. i didnt get a very good look at it but it seamed to have all of the fuel lines hooked up , i still need to take a better look at the bottom of the gas tank and all of the lines. i just cant figure out why when i put it away it didnt leak but when i turn the gas on later it leakes if anybody has an idea or something that i could check. that would be great.
thanks
Old Feb 24, 2008 | 11:51 PM
sprinter10's Avatar
your carb prob sat drie and the float in your carb stuck tap the bowl with the back of a screwdriver or something to trie and free it up. thats what it sounds like to me.
Old Feb 24, 2008 | 11:54 PM
QWODER's Avatar
I think sprinter10 has hit the nail on the head
Old Feb 25, 2008 | 05:52 PM
vinman18's Avatar
thanks alot, il try that
Old Feb 25, 2008 | 09:40 PM
sprinter10's Avatar
hope it works or you will have to take the carb off witch isn't a quick task how these polarises are designed everything has to come off to get to it.
Old Feb 27, 2008 | 07:06 PM
vinman18's Avatar
yeah i tapped on it and i flicked the throttle and it didnt do much so where going to have to take everything apart sadly.
Old Feb 27, 2008 | 11:26 PM
sprinter10's Avatar
o man that stinks it couldn't just be easy. its brop just the flooat you might just have to flip the carb upside down. put the atv on its lid jkjk that could hirt something if you weren't careful. well since you are going to have it off it is proba good idea to clean out everything anyway.
Old Feb 28, 2008 | 09:04 PM
vinman18's Avatar
yeah today i brought my 4 wheeler nut freind over and he took the carb apart and sprayed it with carb cleaner and that fixed it. it realy wasent thet hard of a job. thanks anyway.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
Myronh
Sep 8, 2015 11:27 AM
