Need help with electronics
Old Feb 25, 2008 | 10:26 PM
MrMudManJR's Avatar
Default Need help with electronics
Every electrical component on my 2002 polaris sportsman 400 4x4 will turn on and off the whole day with out my control... The 4 wheel drive, the lights, the starter, the speedometer, the mile gauge...EVERYTHING! I cant ride at night, I cant start it, I cant climb hills...NOTHING! If anyony could help me save time and money Please Please Please help me. Any and all info would be deeply apresiated.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 25, 2008 | 11:54 PM
Freedom500's Avatar
You have a short or a bad connection. The 02 400 has two auto reset circuit breakers, a 10 amp with two red/black wires and a 20 amp with three red/black wires. The breakers are under the hood in black pouches that are about three inches long. Remove the hood and run the bike until the electrical components turn off, then quickly feel the black pouches to see if one is fairly hot. If one is you have a short on that circuit.
Or, you could have a bad connection. Many people have had problems with the kill switch or the plug going into the kill switch on the left handle bar. Start the bike and wiggle the plug and the kill switch. If you do not find a problem at the kill switch, open the head light pod and wiggle the wire on the key switch.
Old Feb 26, 2008 | 12:08 AM
MrMudManJR's Avatar
Thank you sooooo much. I'll be sure to try it all... Thank you.
Old Feb 26, 2008 | 09:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
so if its killing the bike and shutting down you know its got to be a main power source if there is a short grounding out the entire electrical system. imo.
Old Feb 26, 2008 | 06:56 PM
MrMudManJR's Avatar
No it dont shut down the bike but when i go to crank it it wont turn over... Actually nothing happens at all.
But my moms boyfriend did sum reashearch and he found out that its a common problem amung us polaris's
pgamboa
Dec 24, 2023 11:52 AM
dwhipper61
Aug 27, 2015 11:01 AM
moneyrider
Aug 18, 2015 07:15 AM
nilla
1) Engine problems..
Aug 9, 2015 10:02 AM
