Polaris Sportsman 500
Old Feb 26, 2008 | 06:11 PM
candyamick's Avatar
Default Polaris Sportsman 500
our 1996 sportsman 500 has very little power full throttle only goes 20 we put in a new cam shaft check the carb and everything else we could think of still no power please help with any suggestion Thanks so much[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 26, 2008 | 08:40 PM
nickatnite's Avatar
i would check the clutch springs. i have a 2005 500 and it all of a sudden started doing 35-40 all the time. one of the springs was wore out..factory error got it for free and a new belt
Old Feb 27, 2008 | 08:57 AM
lf479's Avatar
Okay I am very new to the polaris world. (just bought mine used
a few months ago). Since you are talking about the same model
I have, what speed should it top out at?? .. just to see if mine is at least
up to snuff with others of the same kind.
Thanks!
Old Feb 27, 2008 | 09:20 AM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: lf479
Thanks!</end quote></div>
around 55 mph
Old Feb 27, 2008 | 11:06 AM
candyamick's Avatar
Thanks we checked that too and it was fine!
Old Feb 27, 2008 | 11:25 AM
heller1's Avatar
is it revving up and not going or does it not even rev up?
Old Feb 27, 2008 | 01:44 PM
candyamick's Avatar
Heller1
It reves up to about half trottle and that's all she's got only goes 20mph it idles just fine. Any suggestions?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 27, 2008 | 01:56 PM
heller1's Avatar
fuel filter or carb. have you ever cleaned the carb?
Old Feb 27, 2008 | 02:11 PM
reno82's Avatar
You say it revs up 1/2 throttle, can you get more revs by pulling the actual linkage on the carb? I always trace from the furtest point back, could you have a throttle problem, maybe a streached cable that is not giving you full throttle?
Old Feb 27, 2008 | 04:14 PM
msatvnut's Avatar
friend of mine had the same trouble while out on the trail..take a look under the throttle box up on the handle bar above the thumb control..his nut to the lever had came loose,and would not open the throttle all the way up..G'
