sporty 500 starter?
Old Feb 28, 2008 | 09:08 PM
polarisbear500's Avatar
Default sporty 500 starter?
I am having issues with what seems to be the starter. plenty of juice from the battery but when i try to electric start it, it will catch for a seconds then stop but if i hold down the start button, it will continue to try for a split second, then stop, then try again, but never for long enough that the engine can crank. the pull start starts it right up though. sound like the starter??
how difficult is it to replace or should i buy a rebuild kit or what? thanks- PB500
Old Feb 28, 2008 | 09:31 PM
Freedom500's Avatar
Try a jumper around the start solenoid (two big wires). If it starts, change the solenoid, a lot cheaper and easier.
Old Feb 29, 2008 | 12:39 AM
94harley's Avatar
When you hold the starter button down i assume it engages briefly and then disengages and the starter continues to spin. Correct? If so, you probably need a new bendix.
Old Feb 29, 2008 | 09:22 AM
no, the starter doesn't continue to spin. it trys to engage, almost a "hickup" if you will, then stops, then "hickup" again, then stop. it will continue to try and engage for a fraction of a second if you continue to hold the electric start down. it seems as if the starter is not making a good connection and can't make a full rotation. thanks- PB500
Old Feb 29, 2008 | 08:54 PM
Freedom500's Avatar
Put a volt meter across the starter. If the meter reads around 12 volts DC when you try to start it, the starter is most likely the problem. If the meter reads around 10 volts or less, you most likely have other problems. If you do not have a meter you can buy a decent one for about $15. A meter will pay for itself over and over again.
Old Mar 8, 2008 | 02:00 AM
how do i replace the starter on a 99 sportsman 500? thanks- PB500
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
